Posted: Wed Dec 08, 2010 12:40 pm |
Hi
does anybody know where the earths are located on a 2001 2.0 HDi!!
Most of my lights have gone crazy & have been advised to check the earths before an auto elec comes to look at it!!
The lights that are going nuts are the brake lights & indicators!! Also the rear fog light indicator light on the dash is permenantly lit!!
Do these all use the same earth connection?
thanks
Craig
| Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes! | |
Posted: Wed Dec 08, 2010 12:50 pm |
You also checked your fuses?
Posted: Wed Dec 08, 2010 1:51 pm |
Check the earth lead from the gearbox to the chassis. A quick and easy way to confirm if its an earth fault is to connect a single jump lead fron the negative battery pole directly to the engine block and see if you still have the problem.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Thu Dec 09, 2010 11:20 am |
Sorted it!! it was the earth connection behind the side trim in the boot near the passanger side rear light cluster!!
Literally i had to do was tighten a bolt up!!
