Latest: Andyblue64
Overall: 17123
Online Now [363]:
Visitors: 362
Today: 22418
Total: 98391170
Forums › The Car › 206 Problems › 1.4 HDI power loss
1.4 HDI power loss
Go to page Previous  1, 2
D4VE
PostPosted: Wed Dec 15, 2010 7:16 am Up
panason1c wrote:
Check out the exhaust first, otherwise it sounds like the 'maf' is bad, remove it from the airbox and try spraying it with electrical contact cleaner. (dont attempt to clean it with anything else!)
Thanks panason1c, they did confirm the fault code for the maf was showing but a new sensor has been fitted, hovever, the fault code not cleared. Once cleared the only fault code it brought back up was the one that lead them to the exhaust again.
Thanks again though, i'll try it if this doesn't work.
panason1c
PostPosted: Wed Dec 15, 2010 7:23 am Up
It does sound more likely to be a blocked cat then, just knock out the innards, a cat is not an mot test item on a diesel so dont worry about that and the car should be a bit more lively without it.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Page 2 of 2
