Latest: dreyfalon
Overall: 17121
Online Now [329]:
Visitors: 328
Today: 53711
Total: 97457450
Forums › The Car › 206 Problems › steering and starting..
varnam
PostPosted: Fri Jan 07, 2011 7:37 am Up
When turning wheel to the right I get a high pitched noise, only to the right though, furthermore car wouldn't start after putting petrol in, but once I took the key out then put it back in it started, could this 2nd problem be the sign of coil pack going?
Current transport\r\n\r\n53 plate peugeot 206 quicksilver\r\n1999 vauxhall corsa , absulute gem\r\n2006 Yamaha cw - 50cc Razz
bertt
PostPosted: Fri Jan 07, 2011 7:58 am Up
The sound when you turn the wheel, had it on a vaxhaul we were selling and it was because on the power steering system there was a leak and the vrring noise was the escaping oil and air within the system, wasnt really igh pitched though :/ check the power steering fluid level
PostPosted: Fri Jan 07, 2011 8:19 am Up
The starting problem will probably be the immobiliser ring not detecting the key.
varnam
PostPosted: Fri Jan 07, 2011 8:27 am Up
Thanks guys ill take a look soon
JDave
PostPosted: Fri Jan 07, 2011 8:48 am Up
Yeah I had the same problem with the noise. There was a crack in my steering rack from the cold weather, that leeked all my fluid which caused the noise. The sooner you get it sorted the better otherwise you will have no power steering and every roundabout is alike a mini work out.
No Joke Neutral
Click To View My Project
varnam
PostPosted: Sat Jan 08, 2011 6:02 am Up
that sounds mightily expensive, i hope its just a topping up the fluid sort of case
