Posted: Thu Jan 06, 2011 2:53 pm |
right my front sidelights arent working, my back lights arent working, 2 of my brake lights arent working, and i hav no clue as to why. i have changed all the bulbs and changed the fuses and still not working and i dont no what else to try
Posted: Thu Jan 06, 2011 2:57 pm |
These things normally fall down to a dodgy earth. Where's lee?
Posted: Thu Jan 06, 2011 2:59 pm |
Does the dipped and main beam work?
Check fuses #11, #12, #18, #34 # in the drivers fuse box. Fuses #5 and #32 in the engine fusebox
You run a +12 feed to each of them to see if they work manually?
Posted: Thu Jan 06, 2011 4:50 pm |
its a bad earth somewhere behind the dashboard i had the same problem
Posted: Thu Jan 06, 2011 4:52 pm |
sweet cheers i will try these in a min
Posted: Thu Jan 06, 2011 4:55 pm |
is there a specific place where the earth is or is it different for everycar??
Posted: Thu Jan 06, 2011 5:14 pm |
and yer both main beam and dipped beam work
MC20
Posted: Fri Jan 07, 2011 3:39 pm |
Cheers found out thqt some wires in boot were touching and short circuited all my lights lol cheers fr all the help
