Posted: Wed Dec 15, 2010 9:41 am |
Hi
I cant check my oil as the dipstick is always covered in thin mud like oil . Which I thought was due to the dip stick seal breaking . Today I opened the oil cap and inside the cap it was full of yellow/white sludge also there was a little steam coming out of the oil filler hole . What does this mean? Ive heard this happens when the head gasket goes but my cars running fine.
Posted: Wed Dec 15, 2010 9:42 am |
my old 106 used to start fine and run fine with a blown gasket aswell
yes, head gasket blow.
you can also check if you got less coolant and the spark plug as well
Posted: Wed Dec 15, 2010 9:49 am |
as said.... head gasket.
Posted: Wed Dec 15, 2010 9:52 am |
Is it always there or just when the engine is still cold from a short journey?
Posted: Wed Dec 15, 2010 10:11 am |
FFS ! ! . . . Nah its like this all the time . Just serviced it last month the plugs were white so running lean and hot . Its started getting hotter than normal . The coolant is a very dark green . And just noticed when idling the exhaust quietly pops now and again missfiring maybe?
So what should I do . Even though it seems fine I guess it would be foolish to ignore it?
Posted: Wed Dec 15, 2010 10:17 am |
i would get it fixed soon. new gasket+skim head
Posted: Wed Dec 15, 2010 10:34 am |
Ok thanks for the fast replys guys !
Posted: Wed Dec 15, 2010 10:45 am |
Seabook wrote: |
i would get it fixed soon. new gasket+skim head |
Don't forget the new timing belt kit while its apart
Posted: Wed Dec 15, 2010 11:33 am |
Is it losing coolant mate?
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Wed Dec 15, 2010 11:35 am |
Just been quoted £600 for new gasket preasure testing and new timing belt and water pump . . How does that sound?
Posted: Wed Dec 15, 2010 11:40 am |
mattievrs wrote: |
Is it losing coolant mate? |
Posted: Wed Dec 15, 2010 11:41 am |
jamie_206 wrote: |
Just been quoted £600 for new gasket preasure testing and new timing belt and water pump . . How does that sound? |
Is that with the head being skimmed aswell?
Posted: Wed Dec 15, 2010 11:49 am |
if i remember rightly, on my 106, it cost me around £350 thats with it being skimmed and al that to....how ever, i have no idea if there's a difference how much more labour is involved from engine to engine
Posted: Wed Dec 15, 2010 11:50 am |
It dosent seem to be losing coolant but its hard to tell with the usless levels on the header .
And yea thats with it being skimmed.
