Forums › The Car › 206 Problems › Perished Pipe. |
Posted: Mon Dec 27, 2010 10:00 am |
One of the pipes on my engine is perished, and is not looking so good.
What is the pipe called so I can get it replaced, and what does it do?
Have circled it in yellow. Thanks.
Posted: Mon Dec 27, 2010 10:54 am |
I think thats the oil breather hose
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Mon Dec 27, 2010 11:03 am |
cam flow pipe i call it, as above i'm sure its a oil breather pipe from the rocker cover to the air inlet
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Mon Dec 27, 2010 11:38 am |
Could swop it for a length of silicon hosing from Ebay...I think you'll need a little T piece in it though. I bet it's not cheap from the dealer. You can cut the pipe up to re-use the end connectors.
Mine just needed a straight run but I reckon you could use the existing angled T piece.
