Forums › The Car › 206 Problems › water pump |
Posted: Mon Dec 20, 2010 12:42 pm |
hi just wondering how much we are talking to fit a water pump to a 206 gti w reg,
has anyone got a diagram or data for water pump
Posted: Mon Dec 20, 2010 12:45 pm |
Dont know the cost but might as well fit a timing belt kit at the same time.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Mon Dec 20, 2010 12:52 pm |
It's listed as a 5 hour job, and if its about £60 an hour labour, you're looking £300. But like panason1c said, get the timing belt done at the same time
Posted: Mon Dec 20, 2010 1:10 pm |
Independent garage will charge half that for labour.
Posted: Mon Dec 20, 2010 2:57 pm |
Trade Rating: +45
you may aswell do the cambelt kit at the same time as if i renember rightly you have to take the cambelt off or something like that to get to the water pump
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
