Latest: sparrowdclxvi
Overall: 17139
Online Now [106]:
Visitors: 105
Today: 24555
Total: 113030067
Forums › The Car › 206 Problems › took my 206 to peugeot today!!!!!!
grantjohn1979
PostPosted: Wed Dec 22, 2010 12:38 pm Up
right took the 206 into peugeot today and they advised me to replace my coolant temp sensor which wernt to bad but did advise me that there were quite a few aftermarket parts on it some id done myself but also he said the ecu was aftermarket as well? and advised me to get a mobile technician out to do another diagnostics aftermarket ecu?help guys n gurls thanks
n/a
PostPosted: Wed Dec 22, 2010 12:40 pm Up
Whats the problem?
We aren't psychic
Dillon
PostPosted: Wed Dec 22, 2010 12:53 pm Up
Staff - Dillon
Lee wrote:
Whats the problem?
We aren't psychic
Slacking Lee? you're supposed to know from the above post everything aren't you? Razz
What's the problem with it having an after market ECU is the car running fine etc?
EDIT: Looking back over previous threads there appears to be miss fireing starting and pick up issues with the car.
grantjohn1979
PostPosted: Wed Dec 22, 2010 12:58 pm Up
yer car runs fine i suppose just gotta replace coolant temp sensor now and most probaly clean the throttle body housing to as well
n/a
PostPosted: Wed Dec 22, 2010 1:56 pm Up
Aftermarket ECU??? I doubt it.
panason1c
PostPosted: Wed Dec 22, 2010 2:40 pm Up
'aftermarket ecu'..........Maybe the car has had a 're-map' and that's what they are refering to?
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
They're trying it on.
