Latest: elelectricistadeMateo
Overall: 17127
Online Now [61]:
Visitors: 60
Today: 9633
Total: 100407843
Forums › The Car › 206 Problems › ecu design fault
ecu design fault
RobertC
PostPosted: Wed Dec 29, 2010 11:02 am Up
would the ecu design fault cause the car to judder as your driving and make the revs go up and down and stall when sitting still
Peugeot 206 XS 1.6 black
PostPosted: Wed Dec 29, 2010 11:03 am Up
What ecu design fault?
PostPosted: Wed Dec 29, 2010 11:05 am Up
A fault in the design could make that happen but they weren't designed with a fault.
RobertC
PostPosted: Wed Dec 29, 2010 11:06 am Up
PostPosted: Wed Dec 29, 2010 11:08 am Up
The ecu is pretty much bulletproof.
Only a Sagem coil pack / NGK spark plugs that really kill them Laughing
Only issue I know of is the silicone grease on the connectors that Peugeot used to protect the terminals, brake cleaner will remove that.
amy-v17
PostPosted: Wed Dec 29, 2010 11:12 am Up
A quick look on Google and it seems like this is an issue. Some people have been saying its cost them £500 to fix!!
Did a pug garage tell you it was an ECU design fault? You should get a second opinion on it.
Luke
PostPosted: Wed Dec 29, 2010 11:28 am Up
Was just about to add that. The connectors are also prone to moisture damage.
We used to have a whole section dedicated to the 'cut-out' problem.
RobertC
PostPosted: Wed Dec 29, 2010 11:32 am Up
nope it wasnt a peugeot garrage
RobertC
PostPosted: Wed Dec 29, 2010 11:39 am Up
i dno what to do i think i will probly take it to another garrage for second opinion
PostPosted: Wed Dec 29, 2010 11:50 am Up
BBA can test / repair ecu's
www.bba-reman.com/uk/index.aspx
Contax
PostPosted: Wed Dec 29, 2010 8:55 pm Up
May be way off but a mate had similar fault with a diesel ford focus some time back and it was the electronic accelerator pedal causing it, he said it made him feel sea sick, I know my 206SW 1.4HDi has this type of accelerator pedal.
I don\'t feel old. I don\'t feel anything until noon. Then it\'s time for my nap.
RobertC
PostPosted: Thu Dec 30, 2010 6:20 am Up
just took it to another garage for a second opinion he had a quick look and thinks its air getting in somewhere and told us to take it to another place for a diagnostics test so took it to another place for this test and come up with a sensor error where it will probly be a new sensor or a split hose or something so iv booked it in to be sorted
so if it is this thing its alot better than i thought and from now on i will always get another opinion lol
amy-v17
PostPosted: Thu Dec 30, 2010 7:31 am Up
I hope that you get it sorted, always good to get a second opinion or take it somewhere you trust Smile
