Posted: Fri Dec 31, 2010 8:38 am |
It's not vvt sensor that's near the coil pack.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Fri Dec 31, 2010 9:51 am |
| nick180 wrote: |
| It's not vvt sensor that's near the coil pack. |
it is the only sensor near the coil pack
Posted: Fri Dec 31, 2010 9:55 am |
is that not the lamdba sensor
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Fri Dec 31, 2010 9:57 am |
its not the arrow pointed its at the end of the coil pack
thats a pic i borrowed of another post
Posted: Fri Dec 31, 2010 10:01 am |
ar right sorry...........
| Mark
Posted: Fri Dec 31, 2010 10:46 am |
The thing next to the coil pack is the VVT solenoid. That controls the oil pressure to the inlet cam pulley.
Posted: Fri Dec 31, 2010 10:27 pm |
cheers for all the advice people gona get the correct tools and time it properly, my freind works for arnold clarke so cany get the correct tools from there and do it properly
| blue gti 180, anthrecite wheels, lowered 60mm, debadged bonnet, debadeged grill, morettes hid in headlights an fogs, full sp pack, WANTED CAT CAMS NOWWWW | |
Posted: Sat Jan 01, 2011 6:26 am |
Didn't say it's near the coilpack I said it's near the tb. And you can see it threw the inlet manifold near the throttle body it's black with a connector going to it and held in by a 9mm bolt I think. I did say it's not the vvti sensor because that's near the coil pack.
Posted: Sat Jan 01, 2011 6:28 am |
| danjames wrote: |
| cheers for all the advice people gona get the correct tools and time it properly, my freind works for arnold clarke so cany get the correct tools from there and do it properly |
Im shocked an Arnold Clark dealer would have the tools to do this.
Posted: Sat Jan 01, 2011 11:54 am |
searching has stopped it was down to flat battery and me not having fitted the alternator yet but still have a missfire, going to try the coil tomorrow
Posted: Mon Jan 10, 2011 4:05 pm |
misfire ended up being injector number 3 wasnt spraying. swapped it with another injector to see if the injector was at fault and they all started spraying lmao all that hassle for somthing so small lol
Posted: Thu Jan 13, 2011 5:03 pm |
| kieron206gti wrote: |
| ive never done a 180 cambelt but my brother has done loads at work and it still takes him 4 hours or so |
Come on kieron 4 hours really i can do it in 2hours if needed to but on average 3 hours as i like to torque up every thing
I can have the old cambelt in my hand in 40mins ish
Kyle
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
