Posted: Wed Jan 05, 2011 9:22 am |
Whenever I start the car, and also when I pull away quickly it sounds like water is sloshing about, coming from the passenger footwell. Anyone got any ideas? Cheers
Posted: Wed Jan 05, 2011 9:35 am |
Heater matrix most probably. Are you losing any of your coolant?
Posted: Wed Jan 05, 2011 10:12 am |
Not that I've noticed :S
Posted: Wed Jan 05, 2011 4:04 pm |
possible the sill drain holes are blocked and as you set off water inside is sloshing about clean out the holes and jack car up so they drain
