Online Now [1406]:
Visitors: 1405
Today: 96348
Total: 151229994
Forums › The Car › 206 Problems › Hissing noise in Passenger footwell???
bendonn
PostPosted: Wed Jan 05, 2011 9:15 am Up
Hi everyone, Just after some advice - have a 206 2.0l HDI. There is a hissing noise coming from the passenger footwell, sounds like air is leaking out but nothing that noticable. When applying pressure to the brake it reduces the noise and sometimes stops it. Any ideas what the fault is here and the cost Im looking at to repair.
Thanks in advance.
206 HDI (2001)
mattievrs
PostPosted: Wed Jan 05, 2011 9:16 am Up
brake master cylinder
NO LONGER ACTIVE ON THE FORUM
bendonn
PostPosted: Wed Jan 05, 2011 9:17 am Up
Quick reply mate, thanks. Any idea on the cost of repair?
206 HDI (2001)
mattievrs
PostPosted: Wed Jan 05, 2011 9:19 am Up
sorry but no mate. It might be ok as its been a while since i owner a 206.Wait a while and you might get a more definitive reply.
bendonn
PostPosted: Wed Jan 05, 2011 9:21 am Up
Ok thanks mate
206 HDI (2001)
Jake
PostPosted: Wed Jan 05, 2011 9:23 am Up
Yeah its the brake servo. Had exactly the same on my car, i think it cost around £100 to get done Smile
Jaykerz.
£96.05 with out ABS for a new one
£119.14 with ABS
Plus labour, unless you do it yourself
It sounds like the brake servo not cylinder. I dont think its anything to worry about after reading some post on here, as long as your brakes are working.
Does it only make this hissing when you apply the brakes and when you take your foot off the pedal?
bendonn
PostPosted: Wed Jan 05, 2011 9:27 am Up
Thanks for replies guys. Yeh when you hit the break it start making the hissing noise, if i tap the break again it will go quiet - brakes are working fine and it got through MOT but its just annoying me now Sad
206 HDI (2001)
AJBUK
PostPosted: Wed Jan 05, 2011 9:35 am Up
Yeah happened to me and had it changed recently cost me £25 for an ABS servo only to find out later that mine wasnt ABS but it still works lol Smile no more hissing!! Very Happy
Taff!
PostPosted: Wed Jan 05, 2011 4:13 pm Up
Hopefully it's fine as my servo has been doing it for a fair while. Passed two MOTs without any issues anyway
206 1.6 Quiksilver
jeoff82
PostPosted: Thu Jan 06, 2011 6:02 am Up
Its the brake servo and it sounds like it is working fine to me. The way to test if its working; Switch off engine, pump brake pedal until it goes hard, hold foot on brake pedal while starting car, pedal should travel towards floor once the engine has started. If this happens its working fine. If your brake servo was not functioning properly you would have a hard to stopping the car under braking, and if it was completely not functioning you wouldnt be able to stop the car!
CFC
