Posted: Fri Jan 07, 2011 4:46 am |
Hi all.
Can anyone help with this problem in my Mom's Pug 2001/51 206 2.0 lx hdi.
Heater blower came on, then off, then on again, then stopped all together.
Is the fuse in the engine fuse box and are there relays etc???
Thanks in anticipation!
Dale.
Posted: Fri Jan 07, 2011 4:56 am |
The fuse is in the drivers side fuse box, that should be your first point of call.
| Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi | |
Posted: Fri Jan 07, 2011 5:03 am |
Posted: Fri Jan 07, 2011 6:59 am |
yeah fuse is in the drivers side, it could be the blower motor has come loose and is jamming that would explain the on off then off as it would eventually short the fuse out, check the fuse first off if that doesnt help maybe try the motor or the switch pannel
Posted: Fri Jan 07, 2011 10:55 am |
I had this problem. Try fidling with the circulation slider to get it to come on. Failing that there is a big plug up in the passenger foot well. I gave this a fiddle and it came on, i have a bad connection i think. I just tapped up the big clump of wires in a position that it works and its been fine for a year and a half
