Posted: Fri Jan 14, 2011 10:28 am |
My car is majorly overheating it will go for 0 - 110 in about 15 minutes...
Which is really bad...
I have noticed there is oil dripping out the bottom and under teh oil cap is a very very very thin layer of mayonaisey stuff.
Could these all be linked?
Does it need a new Head gasket..
How hard is it to replace the head gasket?
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Fri Jan 14, 2011 10:32 am |
uhoooh thats a definite head gasket..
it can be done relatively easily if you are quite mechanically minded/have experience with working on cars
if not its a £400 garage job
Posted: Fri Jan 14, 2011 11:16 am |
yeah head needs fixing, BUT i found if you drain the system replace the fan switch and thermostat and give her a good flushing out, it will sort the over heating out, BUT THIS IS SHORT TERM FIX
Posted: Fri Jan 14, 2011 11:23 am |
Well for all the parts including cam nelt and water pump.... it will be about £130 then i have to fix it.
