Latest: heikkisj
Overall: 17126
Online Now [50]:
Visitors: 49
Today: 839
Total: 100237166
Forums › The Car › 206 Problems › window wipers ?
window wipers ?
carl2275
PostPosted: Mon Jan 17, 2011 10:32 am Up
i've just been trying to find where to put the power lead for my sub from the engine bay through to under the glove box and i've had to drill a hole
and now the window wipers have gone weird as in off means there on auto doesn't work everything does the wrong thing
how do you take the glove box out to get to the wires behind glove box there's a high chance i might of hit a wire
if i can get to it i can fix it but i'm having a few problems with it
i've looked for diagrams and instructions all over but none seem to be any real help
it's a 2003 1.4 16v quicksilver if that makes any difference
please help
PUG91
PostPosted: Mon Jan 17, 2011 10:55 am Up
There's a variety of torx screws around the edge if you pull the lid down, also there's one on the "roof" of the glovebox compartment (if you look up at the top of the glovebox) , best bet is too take the glove box lid off, undo these screws and then you can wobble it out, if I remember right You had to pull it all down a certain way to get it too budge, note the wire for the light inside though the cabling is quite tight.
Not sure about the wipers but there is a grommet behind here you can trail your wiring for your sub though Smile
carl2275
PostPosted: Mon Jan 17, 2011 11:04 am Up
i've got the wire through but i think i've hit one behind there so i need to get behind the glovebox to check the wires and fix them if i've hit one if not then i'm off to the garage
cd2275
PUG91
PostPosted: Mon Jan 17, 2011 11:10 am Up
yeah I gave a quick prayer before taking a drill to the grommet lol, guess you might have just had a bit of badluck Sad
PostPosted: Mon Jan 17, 2011 5:16 pm Up
Main wiring loom passes right through the bulkhead behind the glove box, Peugeot provide a proper place next to it for a extra hole through the bulkhead, you cant really get it wrong Wink
