Posted: Fri Jan 28, 2011 8:52 pm |
keep getting anti pollution fault, ive got a 206 xsi '54' keep getting anti pollution fault? what the hell is it and is it safe to drive for the weekend?
thanks
Posted: Fri Jan 28, 2011 10:01 pm |
Best start off with the lambda sensor.
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Sat Jan 29, 2011 2:37 am |
Howey wrote: |
Best start off with the lambda sensor. |
As above. Or get the fault codes read.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Sat Jan 29, 2011 5:42 am |
Could be anything, get the faults read first.
Posted: Mon Jan 31, 2011 2:09 am |
Don't change anything until you get a code scan. I had the same problem, had the codes scanned and showed bad fuel. Changed fuel filter, reset and scanned, no problems since.
I'm sure Lee can scan your pride and joy for a small fee if you live closeby. Lee where are you?
Posted: Mon Jan 31, 2011 11:09 am |
NXT206 wrote: |
I'm sure Lee can scan your pride and joy for a small fee if you live closeby. Lee where are you? |
I so wish I was close to you, Oz would be a million times better than Sheffield
But yeah, you need the codes read, don't buy anything until you have the fault codes.
