![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › ABS kicking in |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Tue Mar 01, 2011 3:02 pm |
Has anybody noticed on any 206 with ABS, it kick in under light braking just as the car is nearly stationary?? it literally kicks the pedal twice and then stops!!
mine has done this a couple of times in different conditions both dry and wet and at different points on journeys, but not all the time ![Smile Smile](images/smiles/icon_smile.gif)
binding rear drum maybe??
steve
| | ![](images/spacer.gif) |
| If in doubt, drop a cog and put your foot down ![Smile Smile](images/smiles/icon_smile.gif) | |
Posted: Tue Mar 01, 2011 3:14 pm |
check the absring on the driveshaft. very possible it has cracked
Posted: Tue Mar 01, 2011 3:36 pm |
cheers for that will do and i see how that could cause a quick pedal flutter
Posted: Tue Mar 01, 2011 6:12 pm |
SDK206 wrote: |
Never had that one yet.
I can emergency brake assist the car to a stop without the abs cutting in at all ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Wed Mar 02, 2011 3:39 pm |
ha ha, ive jumped on my pedal too and it doesn't do it when i try to force it but mine doesn't have EBA ![Smile Smile](images/smiles/icon_smile.gif)
It is so quick just as the car is coming to rest its stupid why its happening but i'll check my driveshafts for broken pickup rings
Posted: Wed Mar 02, 2011 4:17 pm |
Mine had a cracked ring on the shaft and at 100mph+ the ABS light would come on and and occasionally when parking it would trigger the ABS.
So up the ramps the car went and this is what I found.
![](http://i38.photobucket.com/albums/e105/s1pso/20090625004.jpg~original)
Posted: Thu Mar 03, 2011 7:49 am |
Edward - did your ABS light go out after that as mine did not, even though I got a new ring.
Posted: Thu Mar 03, 2011 12:59 pm |
After a restart the light would always go off.
Posted: Fri Mar 04, 2011 9:18 am |
Maybe my sensor is naffed then, as my fault still comes up but the car is running fine now with a new CV Joint / ABS Ring. The initial problem I had was speedometer intermittently showing incorrect readings and the brakes went a bit d***ky like I was braking on snow.
Posted: Fri Mar 04, 2011 10:40 am |
Does that mean yours is one of the cars that have the speedo operated by an ABS sensor? They don't all work like that.
Posted: Fri Mar 04, 2011 12:06 pm |
What year/model is yours? - 2003 Gti
Posted: Fri Mar 04, 2011 12:38 pm |
Mines an early 2001. Your is multiplexed so will be different.
Posted: Sun Mar 20, 2011 4:37 pm |
Trade Rating: +59
Can you buy replacement driveshaft rings then Paul? As I've got the same problem now!
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon Mar 21, 2011 6:40 am |
G. Seen some on Ebay for about £10 recently. I opted for a new CV Joint instead (where the ring is attached) for about £20-£25.
This ring may fit depending on your model/year ABS Ring
Posted: Mon Mar 21, 2011 9:16 am |
Trade Rating: +59
Thanks mdstone, thats a big help ![Smile Smile](images/smiles/icon_smile.gif)
| ![](themes/base/images/forums/otr.gif) |
