Latest: Stu-mill
Overall: 17131
Online Now [312]:
Visitors: 311
Today: 18025
Total: 104826887
Forums › The Car › 206 Problems › Strange electrics
Strange electrics
rudebwoi93
PostPosted: Sun Jun 19, 2011 1:02 pm Up
Hey guys, so the indicators on my 206 have always been 'erratic' so you would indicate left and it would come one then stop and you'd have to apply more pressure to get it to come on again. But today they stopped working altogether, however I soon discovered that when the headlights are turned up all the way on the indicator stalk they seem to work perfectly. What's the problem? Also don't know if it's relevant or not but the bulb in one of the headlights also went today and now after a while you can't open the car with the keyfob you have to put it in the lock and the alarm will sound when u open the door then you can press a button on the keyfob and it will stop, then for a short while the car will respond to the keyfob.
PostPosted: Sun Jun 19, 2011 1:34 pm Up
Com2000 is fubar'd
rudebwoi93
PostPosted: Mon Jun 20, 2011 4:04 am Up
Lee wrote:
Com2000 is fubar'd
Ah so are the problems interlinked? (minus the headlight bulb) and will simply swapping it out solve the prOblem?
Norvvv
PostPosted: Mon Jun 20, 2011 4:37 am Up
New com2000. You can't replace individual parts.
2001 1.4lx
PrePlexed 5 door.
rudebwoi93
PostPosted: Mon Jun 20, 2011 9:50 am Up
Is there any information on the comm2000 unit? Like what it is, where it is, how you would go about swapping it out eg do you have to remove the airbag...?
PostPosted: Mon Jun 20, 2011 9:54 am Up
Drivers airbag & the steering wheel have to be removed to change it.
The com2000 unit is the complete indicator / wiper stalk / rotary switch unit behind the steering wheel, its one big lump with lots of connectors on the back & the early ones always go wrong Laughing
