Latest: Andyblue64
Overall: 17123
Online Now [42]:
Visitors: 41
Today: 13567
Total: 97994759
Forums › The Car › 206 Problems › someone reversed into me :@
Will180
PostPosted: Wed Jun 08, 2011 8:54 am Up
well as title says on saturday/sunday while the car was parked at my girlfriends house her neighbour managed to reverse out of his drive across the street and straight into my poor innocent passenger door! Sad
He knocked straight away and such and exchanged details but i felt it was more safe to have to car checked over by time served mechanic family friend and see if anything other then the door had been damaged.
luckily other then a slight tracking adjustment the car is fine. and i have ordered a new door from hanpug25 from another Gti180 luckily in the same colour. my question is really what sort of hassle will changing over a door present? i know the locks will need to be changed is that an easy task? also what else will need to be done?
04/07/10. Black 206 XS 1.6 - Sold
29/03/11. Black GTI 180, Full Sp Kit
JE_180
PostPosted: Wed Jun 08, 2011 9:07 am Up
Just wiring the electric windows and mirrors in by the sounds of it?
PostPosted: Wed Jun 08, 2011 9:10 am Up
Lock barrel for your key obviously and yes it's pretty straight forward. Unless the wiring is different (why would it be?) then no nothing else except the obvious like mirrors and door cards.
Slickrikk
PostPosted: Wed Jun 08, 2011 9:12 am Up
Scotland Area Rep - Slickrikk
If it is defo just the door its damaged it should be quite a easy job! So yeah Window, Mirrors and Speaker wiring but just watch what your doing when taking it off then just repeat the process!
Aegean Blue 206 Gti 180
Will180
PostPosted: Wed Jun 08, 2011 9:19 am Up
fair enough thought that would be the case. just wondering how easy the lock barrel is to remove? i think thats the only part of the door i havnt taken off myself at some point in time the rest im comfortable to do
Rob2859
PostPosted: Wed Jun 08, 2011 9:24 am Up
Tracking Adjustment? Caused by him? You can't "knock" the tracking out. It has bent something, ether the wishbone or the track rod. Its very hard to tell if the wishbones are bent or not but if its not the track rod it will be that. I went up a kerb with a a bit too much force and bent a wishbone; after a few months it has shagged the bushes.
meady
PostPosted: Wed Jun 08, 2011 9:36 am Up
Trade Rating: +45
there is a thin u shape bit of metal around the lock barel againt the door. Just use a flat head screwdriver to slide it away from the lock and it will fall off the door. Couldnt.be easier mate
TEAM - I HATE FACEBOOK Smile
Will180
PostPosted: Wed Jun 08, 2011 9:49 am Up
yea it was a track rod end. its been sorted now tho i never used the term "knock" or said he had knocked my tracking out i said there was a slight adjustment to the tracking to get it fixed that being having a new Track rod end fitted. so thats simple enough, just need to wait on hanpug to send it on its way Smile
Rob2859
PostPosted: Wed Jun 08, 2011 9:56 am Up
That good anyway. Just making sure because a lot of people seem to think that after and impact the tracking can just be realigned and thats it.
Kersh
PostPosted: Wed Jun 08, 2011 9:58 am Up
you have the worst luck!
Member number: 36
Will180
PostPosted: Fri Jun 10, 2011 8:17 am Up
wheres my damn door >.<
Danw_VVT
PostPosted: Fri Jun 10, 2011 8:19 am Up
late reply but dont be to hopeful about the colour either it may be a differnt variant
Will180
PostPosted: Fri Jun 10, 2011 8:25 am Up
yea im expecting there to be a slight difference but being black it shouldnt be so noticeable...fingers crossed
Danw_VVT
PostPosted: Fri Jun 10, 2011 8:28 am Up
hope your right bud! would be a lucky find if its perfect! lol
Will180
PostPosted: Fri Jun 10, 2011 8:36 am Up
had my car booked in for a full detailing aswell on wednesday Sad had to cancel till the bloody door arrives. and hanpug has went quiet since i sent over the payment lol
