Hi, my 03 gti has a changer in the boot. Doesnt seem to be getting power as i cant eject the cartrage and on the headunit its not allowing me to select it.
Will be pulling the headunit out to see if its plugged in but was wondering if there's a fuse for it.
Dont have any books with wiring diagrams in to check myself
Any help would be greatful.
Posted: Sun Aug 06, 2017 8:51 am
Have you also pulled the cd changer out the slot in the boot to see if the cable is plugged in to it?
Might be worth rebooting the BSI unit.
Do you have Peugeot Planet?
If you do, ECU configuration and services then global test will show the cd changer on the network.
Black03GTI
Posted: Sun Aug 06, 2017 9:52 am
Hi, cheers for awnsering. It wasnt plugged in to my headunit. Now seems fine.
Im considering getting peugeot planet. As also have airbag fault flagging up and the cd player in the headunit seems to be playing up. Its my 4th 206 but first with a changer so all new to me
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
