Latest: heikkisj
Overall: 17126
Online Now [162]:
Visitors: 160
Members: 1
Today: 10845
Total: 100320237
Forums › The Car › 206 Problems › big end bearings
big end bearings
mjsroofing
PostPosted: Sun Jul 24, 2011 2:42 pm Up
you might of seen that i put a thread up about a bottom end knock, well i think its a good idea to change the big end bearings. Question is where do i get them from. How much will they cost. I've never had to buy any before.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
troy
PostPosted: Sun Jul 24, 2011 3:10 pm Up
if your big end bearings have gone it has caused damage to the crank also. the job entails taking the head off, the pistons out, removing sump, and removing crank to be re-ground then you have to fit larger bearing as the crank has been ground.
all in all, its 100x easier to fit a new engine and probably cheaper
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
If the bearings need changing the crank will likely need regrinding too.
Rincewind
PostPosted: Sun Jul 24, 2011 4:33 pm Up
What He Said
206 XSI 1.6
Seb
PostPosted: Sun Jul 24, 2011 4:53 pm Up
Staff - Seb
Change the engine. Even the GTi engines go for like £100 or so.
