Latest: heikkisj
Overall: 17126
Online Now [40]:
Visitors: 39
Today: 20541
Total: 100282862
Forums › The Car › 206 Problems › wheel bolt confusion...
PostPosted: Tue May 29, 2012 7:31 am Up
I REALLY want to fit my wheels now it's getting annoying, but I only have a set of steel tapered bolts and XL alloy tapered bolts.
Will i definitely die if I fit them with the steel bolts? because I read somewhere it's ok if they are tapered (which the wheels are obviously)
If not, my options are fitting spacers which I'm not 100% sure i want to do now i've test fitted them again as they already stick out, or buy some alloy bolts Sad
PostPosted: Tue May 29, 2012 7:35 am Up
how long is the thread on the bolt?
you need at least 35mm thread on taper bolt on standard 25 offset
PostPosted: Tue May 29, 2012 7:37 am Up
the threat on the steel bolts is about 20mm
the thread on the alloy bolts is about 45mm
the wheels won't be standard offset but I guess the steels are too short and alloys too long so I might as well buy some shorter alloy ones?
PostPosted: Tue May 29, 2012 7:57 am Up
Just cut the threaded part of the alloy bolts down is another option IF done CORRECTLY!
PostPosted: Tue May 29, 2012 7:58 am Up
well you need to know what offset are you running before you can decide what bolts you need.....
PostPosted: Tue May 29, 2012 8:36 am Up
not reallllly they just need to be shorter than the alloy ones i've got and longer than the steel ones... but thanks
i'm just gonna go down to the scrappy and take a bolt and find some that are the same but shorter
PostPosted: Tue May 29, 2012 8:51 am Up
i think i still got some taper bolts in leeds.
i can check the length tonight
PostPosted: Tue May 29, 2012 8:56 am Up
Fire up the angel grinder Whistle...
shell-vt
PostPosted: Tue May 29, 2012 9:54 am Up
Trade Rating: +46
ive got loads of taperd alloy bolts
york 16,3
PostPosted: Tue May 29, 2012 1:29 pm Up
Found them.
25mm thread for standard pug alloy (taper)
12+4 locking +2 key.
you can pick them up at leeds uni tmr if you want them.
PostPosted: Tue May 29, 2012 1:44 pm Up
Seabook wrote:
Found them.
i'm home now mate came back from uni on sunday Sad damn
PostPosted: Tue May 29, 2012 1:53 pm Up
JordGJ wrote:
Seabook wrote:
Found them.
Laughing
never mind. They are fairly heavy to post.
you can probably get them cheaper from scrappy.
00budham00
PostPosted: Tue May 29, 2012 4:04 pm Up
Call Suffolk Fastners m12 1.25 tpi and mm in length you require just got mine from there
