Latest: S2cgm
Overall: 17178
Online Now [123]:
Visitors: 121
Bots: 2
Today: 82898
Total: 135892400
Forums › The Car › 206 Problems › Uneven front tyres wear?
kit325
PostPosted: Sat Aug 27, 2011 6:15 pm Up
Both of the outer edges of the front tyres were wear out, tyres pressure is alright and the car movement is terrible on uneven surface.
here's the pic on the outer edge,
here's the pic on the inner edge,
Ps: It will make tyres squeeking sound (like tyres breaing hard) when turning on small roundabout.
If anyone have any idea please share!
Cheers!
kit
craigy00craig
PostPosted: Sat Aug 27, 2011 6:17 pm Up
I think tracking issues often cause uneven wear on tyres, have you had it checked recently?
Progress Threads:
kazbah
PostPosted: Sat Aug 27, 2011 6:23 pm Up
Yeah, defo get the tracking checked and also your tyre pressure, low pressure can cause uneven wear. Get the camber checked too just incase
Edited to add: Sorry didn't notice the bit about saying the pressure was ok!!!
Red 206 1.4 LX Petrol
In need of cherry red bonnet and front wings and more importantly a rear axle... can you help?
fatboyslim
PostPosted: Sat Aug 27, 2011 7:10 pm Up
Incorrect toe-out would cause inner edge wear
Incorrect toe-in would cause outer edge wear
Of course incorrect camber also causes excessive edge wear
Yes I own a CC and I'm neither gay or a hairdresser!!
kit325
PostPosted: Sat Aug 27, 2011 7:11 pm Up
Alright, might go to national tyre centre for alignment. I changed both of my front shocks few month ago, will this affect my alignment?
One more thing want to ask is do 206 camber adjustable?
Many thz!
kit
PostPosted: Sat Aug 27, 2011 7:49 pm Up
Toeing in.
S222Chan
PostPosted: Sat Aug 27, 2011 9:00 pm Up
I think there is a bit of adjustability in camber,
but only slightly, to allow for slight tweaks/corrections to the camber angle.
Not 100% on this though.
Deckchair5
PostPosted: Sun Aug 28, 2011 12:31 am Up
You should always recheck the tracking if you change front suspension. As you have both front tyres burning off then it's almost certainly a tracking fault
fatboyslim
PostPosted: Sun Aug 28, 2011 1:05 am Up
What He Said
When I worked at Kwik-sh** if we changed front shox wheel alignment check/adjust was included in the price
PostPosted: Sun Aug 28, 2011 2:31 am Up
Make sure you have new tyres on before the tracking is checked, otherwise it's still going to be out.
If you can't afford the tyres yet, put the rear ones on the front just so that the car sits evenly.
PostPosted: Sun Aug 28, 2011 6:17 am Up
Replace the tyres if they're illegal (obviously), but you don't need new tyres before you can have the tracking done Shocked
Swapping tyres round might spread the wear out, but will only mean you'll need 4 tyres not 2 & won't change how 'the car sits evenly'.
Just get the tracking done asap.
kit325
PostPosted: Sat Sep 10, 2011 12:27 pm Up
All sorted! 2 tyres replaced and have the tracking done in national tyres. Handling now is much much more better and according to the guy my front wheels got too much toe in.
kit
