Posted: Sat Nov 19, 2011 3:06 am |
Posted: Sat Nov 19, 2011 4:04 am |
1) No need to post your VIN
2) Aerial on ignition barell definately OK?
3) You can always re-flash the ECU with the latest software but not sure
how much it would help in this case.
Posted: Sat Nov 19, 2011 4:43 am |
I think I have a virgin dump, will check.
Don't forget to correct checksum when using universal software
Posted: Sat Nov 19, 2011 6:40 pm |
V9977 wrote: |
how much it would help in this case. |
Thank mate..
1. Ok friends ... I will edit my post ....
2. Yes ... all works very well ... transporder well recognized ... can be seen in the attachment below.
3. When i try to download the software for the ECU. PP2000 mentioned that there is a new version for solving the problem of "knocking problem".
Posted: Sat Nov 19, 2011 6:59 pm |
Lee wrote: |
Don't forget to correct checksum when using universal software |
Thank you master ...
My friend, you are truly my savior.
I use Willem Prog / PonyProg to open the dump file in the EPROM 95160. About your virgin dump, It still requires re-coding or already in the unlock? I hope I get way out of this problem.
Actually my car has been put into the nearest Peugeot dealer., But after working for almost a week they can not provide a clear conclusion .. huffffffffff ... They were asked to replace ecu but they do not want to guarantee that it will solve the problem ...... , so finally, I pull my car back to my garage.
regards
Posted: Sun Nov 20, 2011 5:09 am |
Were they not able to update/re-program the ECU with PP2000 at the dealer's?
Posted: Sun Nov 20, 2011 5:20 am |
Post thedump and I'll remove or virginse the data
Posted: Sun Nov 20, 2011 5:55 am |
Lee wrote: |
Post thedump and I'll remove or virginse the data |
Cool.
Posted: Mon Nov 21, 2011 10:48 am |
V9977 wrote: |
Were they not able to update/re-program the ECU with PP2000 at the dealer's? |
Yes. we certainly can update the software at authorized dealers, but i believe they certainly do not want to re-code immo via dump techniques.
If we buy a Brand New ECU, only authorized repair shop who can do the reprogramming software from scratch (or maybe someone got access to PSA ). It because they have our car history, configuration data and other related matters.
The new ECU has only one chance for coding pin and when an error occurs it will be a big problem (dump techniques maybe the solution). Corect me if i am wrong ... friend
Posted: Mon Nov 21, 2011 10:53 am |
Lee wrote: |
Thanks you so much. I'll try to take the dump file tomorrow .. My Hot Air Gun possible in less than optimal conditions are now . Preparing to look for another one tomorrow afternoon ...
regards
Posted: Sat Nov 26, 2011 2:27 am |
Lee wrote: |
hi friend
I need your help and assistance. thank you for your kindness
here is ecu dump for my car ...
Please check it out......
My Immo Code RJ4N
Dump S2000PL4FC5-Eprom 95160
Posted: Sat Nov 26, 2011 4:32 am |
Hi,
You don't have a PIN programmed into that dump
Yours.....
Pin Programmed in.......
Immo off.......
See the difference?
I can upload the files, but not sure if they will work as I think the original dump might be corrupt
Posted: Sat Nov 26, 2011 4:47 am |
You cant beat a good dump in the morning
Posted: Sat Nov 26, 2011 7:12 am |
Lee wrote: |
Hi,
I can upload the files, but not sure if they will work as I think the original dump might be corrupt |
Yes, I understand the difference. It's likely the file has been corrupted. I hope you can upload that file, so I can try to do the writing process to the chip. I will report the results as soon as possible to you friend ....
What if I have the raw files from the Peugeot 206 S2000-PL4FC5 ECU? whether it will become easier or the same result?
thank you very much.
Posted: Sat Nov 26, 2011 7:20 am |
Here are the two files.
The one with the pin programmed in, and the one with the immo off.
I'll PM you the password
