Latest: heikkisj
Overall: 17126
Online Now [67]:
Visitors: 66
Today: 10809
Total: 100383550
Forums › The Car › 206 Talk › Best place to get Peugeot Alloys
Sam19
PostPosted: Wed Nov 16, 2011 5:23 am Up
I currently have 17" alloys on my 206 but want to get some standard peugeot alloys on it as I keep curbing my alloys and wrecking my tyres!!! Where is the best place for me to get standard peugeot alloys?
Black 1.4i Fever
PostPosted: Wed Nov 16, 2011 5:26 am Up
Here.
Big_Rich180
PostPosted: Wed Nov 16, 2011 5:29 am Up
Someones going to say it so i will...why not just not curb your wheels??
If you curb pug wheels you could still wreck your tyres.
Sam19
PostPosted: Wed Nov 16, 2011 5:36 am Up
lol i havent curbed them recently but just figured that its probably gonna be cheaper getting standard alloys than paying for tyres for my current alloys. I keep having problems with tyres that I put on my front alloys. I don't know whether this is due to the tyres not being sealed correctly to the alloys but my front tyres keep deflating and coming away from the alloys.
Black 1.4i Fever
gazza82
PostPosted: Wed Nov 16, 2011 5:49 am Up
1) Do the tyres have rim protection? If not try some that do. I've had these on my Alfa for around 9 of its 12 years and the rims are damn near perfect .. (wish I could say the same for other parts where they are corroding though .. any small damage to the lacquer and once the water and salt gets in, they are done for. Still a refurb should be easier)
2) Have you got the right width tyre? I see so many cars now with wide wheels but the tyres are far too narrow meaning that the rims are projecting outside the side walls. Absolutely no protection to hundreds of £s of alloys ... can't think the handling is that great either Rolling Eyes
PostPosted: Wed Nov 16, 2011 6:00 am Up
Agreed. Some people do it for looks Rolling Eyes
Sam19
PostPosted: Wed Nov 16, 2011 6:02 am Up
No dont think the tyres do have rim protection.
Is it gonna be cheaper for me to get standard peugeot alloys than to but new tyres for my alloys? The alloys are terribly curbed admittedly from myself and the previous owner so I dont know whether this is a factor that is affecting the tyres that are currently on it?
Black 1.4i Fever
pug206lx
PostPosted: Wed Nov 16, 2011 7:31 am Up
check the tyres are the correct ones for the rims
If they are get a garage to remove the tyres from the rims, clean the rim edge and put bead sealer around the rim and remount the tyres.
gazza82
PostPosted: Wed Nov 16, 2011 8:28 am Up
Two tyre fitters from different companies have both told me Pug wheels are a pain to seal. They clean the rims now with a wire cup brush on a drill and one uses some black gunk to help seal the tyres.
If the rims have taken a major hit, you could have some fine cracks in the rims which is letting air out. Or the tyre wall is damaged.
On cost, it depends how much the tyres cost. Rims are usually around £100 each, but tyres can be more or less depending on make/size/quality. I could get tyres for around £40 each ... I usually spend around £90-100 especially for the 206CC and Alfa as they get "harder use" .. Wink
pwbadi
PostPosted: Fri Jan 13, 2012 2:04 pm Up
Might sell my alloys if I can find a set of steel wheels. ( I already have one)
206 1.4 Hdi
PostPosted: Fri Jan 13, 2012 4:36 pm Up
Try learning to drive correctly first Rolling Eyes
D4NTP
PostPosted: Fri Jan 13, 2012 5:00 pm Up
Or just fit a big rubber band and a metal pole......bit like a dodgem....
Rob2859
PostPosted: Fri Jan 13, 2012 7:18 pm Up
Scrap yards for a cheap set. You could learn not to kerb them as others have said. The occasional scrape happens to everyone but you should need to use the kerb to park properly.
PostPosted: Sat Jan 14, 2012 4:21 am Up
Not if you drive correctly it doesnt.
I havent yet managed to damage / scrape a wheel in 17+ years of driving.
Rob2859
PostPosted: Sat Jan 14, 2012 4:29 am Up
Ok well the majority. I have not scrapped mine although a tyre machine has taken some paint of the lip Evil or Very Mad
