Posted: Sat Mar 17, 2012 4:02 pm |
Ok the fan on my 206 gti doesn't seem to work I searched on here and read if I put the air con on the,fan should come on but it doesn't
The temperature got to 90 in traffic and fan still didn't come on luckily we started moving and it cooled down a bit lol
I read that if you disconnect the temperature sensor the fan automatically comes on, where about's is the temperature switch?
Posted: Sat Mar 17, 2012 4:22 pm |
Just managed to find it(I think) the,plug between the head and the battery box with a green plug?
I unplugged it and turned ignition on and also started the car up and still got no fan
What's the next step or next thing to check?
Posted: Sat Mar 17, 2012 4:31 pm |
Check the connections on the fan, there known to corrode.
Posted: Sat Mar 17, 2012 4:38 pm |
| LeeThr wrote: |
| Check the connections on the fan, there known to corrode. |
Where abouts is the connection to the fan? Can you get to it or do you have to take the bumper off
Posted: Sun Mar 18, 2012 5:09 am |
You'll need to take the bumper off, only a five minute job.
Run a +12v direct to the fan to see if it works.
I have a working fan and loom for sale if you need one.
Posted: Sun Mar 18, 2012 5:38 am |
You can get to the relays if you just take the front grill off. The relays will likely be crusty...for a more thorough check and repair you are best to take the bumper off.
Posted: Tue Mar 27, 2012 2:29 pm |
The top grill or lower grill?
