Latest: Andyblue64
Overall: 17123
Online Now [211]:
Visitors: 210
Today: 24648
Total: 98028641
Forums › The Car › 206 Talk › need information 2.0 gti 140 caliper plug and play with 1.6
heyziq
PostPosted: Thu Apr 05, 2012 8:32 am Up
as above,is the caliper is direct swap?, i know nothing to do with abs, will i need gti disc too?
heyziq.com
PostPosted: Thu Apr 05, 2012 11:07 am Up
Depends which 1.6. The 1.6 16V should have indentical calipers.
heyziq
PostPosted: Thu Apr 05, 2012 12:05 pm Up
1.6 16v im using.. can use with gti 140 caliper?
heyziq.com
PostPosted: Thu Apr 05, 2012 12:26 pm Up
Careful though because depending on age GTi's (and XSi's) have different offsets for the discs therefore the calipers are different too.
heyziq
PostPosted: Thu Apr 05, 2012 9:22 pm Up
mine is from 1.6 16v station wagon japan spec
heyziq.com
