Latest: DanDan17
Overall: 17128
Online Now [49]:
Visitors: 48
Today: 12711
Total: 100532652
Forums › The Car › 206 Problems › Front n/s clunk, knock
rick-gti
PostPosted: Wed Aug 22, 2012 2:59 am Up
Rite i have had a clunk, knock coming from the front n/s wheel. there's no movement in the ball joint or steering. Am i rite to say it could be the strut top bush? When the cars jacked up there is abit of movement in the spring. I dont want to start buying parts to find its not them that need replacing. Need to get the car spot on ready to sell.
clio 197sport owner
PostPosted: Wed Aug 22, 2012 3:39 am Up
could be topmount bearings, does it make the noise when turning while not moving/driving car?
somtimes the spring will jump round while turning if someone can have a look while you turn left to right etc.
failing that could be drive shaft.
rick-gti
PostPosted: Wed Aug 22, 2012 3:56 am Up
It makes the noise when driving and going over bumps, can feel it through the steering. I do think it could be the driveshaft as its got a judder when i take off sometimes.
clio 197sport owner
DeadEyePaul
PostPosted: Wed Aug 22, 2012 4:03 am Up
Get someone to turn the steering whilst it is stationary the spring should not turn on the spot. If it does it's the top mounts
Sprotty
PostPosted: Sat Aug 25, 2012 8:27 am Up
Check your top mount bolts are tight! Had this on mine. Changed bottom arms and it turned out to be loose bolts!!! Doh.
Life at full throttle...
rick-gti
PostPosted: Tue Aug 28, 2012 2:01 am Up
Ive checked for play and there's none. Im now thinking the driveshaft could be the issue. Im thinking of getting some lowering springs so will be removing the shocks so can have a good check over the top mounts.
clio 197sport owner
LeeMaddern
PostPosted: Tue Aug 28, 2012 2:05 am Up
Driveshaft bearings or bottom arm mate
More photos on FaceBook - www.facebook.com/lmaddern1
rawills
PostPosted: Thu Aug 30, 2012 5:39 pm Up
had the same clunking noise, new lower front rear and mid bushes and top mount strut bush changed, not heard it since Smile
Who\'s coat is that jacket?
