Posted: Fri Nov 16, 2012 9:28 am |
Hello chaps, I'm having a intermittent passenger air bag issue and also a strange flicker on the clock dials when starting engine up,
heres my diagnostic reading
any ideas for what needs changing?
oh and pug just aint being helpful, they said they have to have an engineer check all the wiring!
p.s its a 2003 2l hdi
Posted: Fri Nov 16, 2012 9:38 am |
Yep cable under the steering wheel in the fusebox! Sure thats the fault i had and fixed that way! "Orange cable"
Posted: Fri Nov 16, 2012 9:42 am |
| iainlovatt wrote: |
Yep cable under the steering wheel in the fusebox! Sure thats the fault i had and fixed that way! "Orange cable" |
hiya, anyidea what the cable goes to and which fuse or relay it goes to, as im sure there's gonna be a few orange cables in that area
Posted: Fri Nov 16, 2012 9:55 am |
Thick orange one! Cant tell you more without looking and im currently in work!
Posted: Fri Nov 16, 2012 10:07 am |
| iainlovatt wrote: |
| Thick orange one! Cant tell you more without looking and im currently in work! |
thats a poor excuse lol
ok mate, cheers
Posted: Fri Nov 16, 2012 10:26 am |
I had the same fault with my passenger airbag. I just pushed all the plugs under the steering wheel until it the light went out, it was the first large white one iirc
| You never really learn to swear until you learn to drive | |
Posted: Sat Nov 24, 2012 8:07 pm |
bump
Posted: Sun Nov 25, 2012 10:34 am |
Have you got a switch to turn off the passenger airbag in your car? Check that. Put the key in and turn it on and off a few times, also check the connection at the back of the switch.
Posted: Sun Nov 25, 2012 10:39 am |
| pug206lx wrote: |
| Have you got a switch to turn off the passenger airbag in your car? Check that. Put the key in and turn it on and off a few times, also check the connection at the back of the switch. |
yeah, I have replaced the airbag switch, still got the same problem
