Online Now [253]:
Visitors: 252
Today: 65631
Total: 127816377
Forums › The Car › 206 Problems › BSI Faults
BSI Faults
JamieM
PostPosted: Thu Jan 17, 2013 6:03 pm Up
Issues
-Horn sounding upon unlock ; won't turn off until you physically sound it.
-Air bag fault; Passenger airbag disabled
-Radio turning volume up to max
-ABS fault
-ESP failure
All the above mine has/had. I thought I required an update and many agreed. Recently my car required a new battery as it could not hold it's charge resulting on many jump starts. Since I got my new battery the car hasn't missed a beat it feels much more alive. The faults seem to have been rectified by the battery.
Could the faults all have been some sort of safety measure because the battery wasn't supplying enough juice to run the systems safely?
What do we think? I'll report back in time to say if it's lasted but so far my car runs bang on and they always occurred before the battery.
Aegean Blue 206 GTi180
Taff!
PostPosted: Thu Jan 17, 2013 6:18 pm Up
I'm getting a lot of these warnings too. I bought a cheapf battery before and it generally seemed ok until recently with cold starting issues, speedo issues, some o your messages and blown bulbs. I've been suspecting it for a while but this has peeked my interest. How long has it been running ok?
Edit. What brand battery are you now running too?
206 1.6 Quiksilver
JamieM
PostPosted: Thu Jan 17, 2013 7:04 pm Up
It's been running ok for 3 days on every start up. Used to be almost every time.
It's a Jap or Chinese battery not sure the brand sorry, I'll look tomorrow if I remember.
Taff!
PostPosted: Fri Jan 18, 2013 2:23 am Up
That's cool. Mine has been doing it every day too so would gladly take three days. I have a lion battery from ECP and its ratings are very low so think at the least ill be able to start the car on a cold day
206 1.6 Quiksilver
PostPosted: Fri Jan 18, 2013 8:29 am Up
Plentyn of on-line battery suppliers will do you amazing prices. Some good motor factors will get close if you prefer to look the seller in the eye.
www.tayna.co.uk/
I usually use this on-line supplier if a local supplier isn't close to the price.
PostPosted: Fri Jan 18, 2013 8:49 am Up
Its very very common for any multiplexed network vehicle to develop ghost faults through a dying battery. If you need to jump start it once (dont advise AT ALL) then replace it.
It can even eventually lead to system failure, so just get it checked by a good tester (an i dont mean multimeter) if you are in doubt
Taff!
PostPosted: Fri Jan 18, 2013 9:38 am Up
Just put a decent rated Varta on mine. Fingers crossed it sorts it otherwise I'm going to use the snow as an excuse for a front ender!
206 1.6 Quiksilver
PostPosted: Fri Jan 18, 2013 10:09 am Up
+1
Voltage check will give you a reasonable battery charge indication - provided that you take battery temperature into account but that won't give you any check of battery capacity or abiltiy to deliver current when under load.
JamieM
PostPosted: Sat Jan 19, 2013 6:25 pm Up
Still running sweet as a nut no faults at all!
PostPosted: Sat Jan 19, 2013 6:43 pm Up
Yeah just put a Bosch s4 in mine. Didn't realise my old battery wasn't even the right size. Starts a lot smoother now, and holds it charge!
PostPosted: Sat Jan 19, 2013 7:17 pm Up
Plenty of room to put a larger battery in the battery tray of a 206. I had a "spare" 096 type battery and the only thing I needed to do was move the holding down bolt to another slot in the tray as the battery is longer.
The longer battery made it a bit fiddly to get the bolt in but not that much trouble.
Same width and height as the recommended battery just 60mm longer but nearly twice the capacity.
Standard = 44AH and 360CCA
Now fitted = 74AH and 700 CCA (nearly new removed from 2.4 diesel Alfa)
Nothing will stop this car starting now! Well, nothing except a burnt out starter motor (joke.)
Taff!
PostPosted: Sun Jan 20, 2013 8:50 am Up
Mine had it again earlier. Been running well since Friday and just experienced it just now. Argh!
206 1.6 Quiksilver
JamieM
PostPosted: Sun Jan 20, 2013 9:26 am Up
Oh no Sad
Just started mine, sweet as a nut.
Hopefully it's cured it then in my case.
Taff!
PostPosted: Mon Jan 21, 2013 6:36 am Up
Light bulbs haven't blown though so that's a plus providing it stays that way. Garage still reckons its a dodgy connection somewhere which is dropping the voltage.
206 1.6 Quiksilver
JamieM
PostPosted: Wed Feb 06, 2013 4:45 pm Up
Again probably my last bump on this, my car is still running sweet as a nut with no faults so the new battery must have sorted them out.
None of the faults have happened since the new battery and I have had the faults since I got the car 2 years ago.
