Posted: Wed Jan 30, 2013 5:31 am |
Hi all. The car has been starting fine, when cold.
When it's warming up it'll start sometimes and just clink some others.
When it's warm it just clunks without turning over
Starter motor fault?
| Peugeot 206cc SPL build
2011 - 2 vibe 12" spaces, 38hz ported box, 2.5k Ground zero Nuclear mono - 141.2db @ 38hz
2012 - GZ Nuclear 12"s, 33hz box, 2 x 2.5k GZ Nuclear monos, 8" GZ comp mids, 4" GZ tweeters - 144.0db @40hz off 1500wrms
build thread -http://www.206info.co.uk/Forums/viewtopic/p=486554.html#4865540 | |
Posted: Wed Jan 30, 2013 9:44 am |
Sounds like it mate, this is what mine started doing when mine went couple years back. just try disconnecting the terminals giving them a good clean and reconnect them could be just a loose connection.
Posted: Fri Feb 01, 2013 10:31 pm |
Replaced the starter motor and voila! Problem solved.
