Latest: Stu-mill
Overall: 17131
Online Now [304]:
Visitors: 303
Today: 88079
Total: 104773626
Forums › The Car › 206 Talk › rocker covers 138 gti
REVHEAD
PostPosted: Sat Feb 09, 2013 4:19 pm Up
can anyone tell me the torque settings on the rocker covers ?
TREV10
iainlovatt
PostPosted: Sat Feb 09, 2013 4:33 pm Up
Tight. Lol sorry I always make sure they are on tight but not too tight don't want to damage to bolt or the cover itself.
(My Garage)
PostPosted: Sun Feb 10, 2013 3:54 am Up
They're only small so the torque setting isn't that high. 8lb ft.
SinfulDesignCom
PostPosted: Sun Feb 10, 2013 7:27 am Up
yes - overtighten and you will splay the gasket and get oil leakage. Finger tight, plus a little.
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
