Online Now [252]:
Visitors: 251
Today: 36089
Total: 127585589
Forums › The Car › 206 Problems › quick question
quick question
Baggiesfan01
PostPosted: Wed May 15, 2013 6:50 am Up
I have a 206 2 litre turbo diesel on a x plate. I have developed a soft brake pedal. i went to my garage and adjusted the handbrake and it brought the brake pedal back up it was quite firm. But after the trip i took over the weekend in which i covered 333 miles it's going soft again and the handbrake is still as it was after the adjustment.
Now my first thought is master cylinder as Brake fluid hasn't dropped to indicate a leak anywhere. anyone else have any ideas.
Brakes are good but just got a soft pedal compared to when it was adjusted.
Pug 2.0 HDI owner
Tolkienfan001
PostPosted: Wed May 15, 2013 7:42 am Up
Trade Rating: +13
I would go with your reasons above, but as you have had the handbrake adjusted it could also be a worn cable? I had this on my Astra. Kept adjusting the HB cable but in the end it needed replacing.
2005 1.4 16v Sport
Check out my 206 here!
Baggiesfan01
PostPosted: Wed May 15, 2013 11:31 am Up
Cheers will keep it in mind.
Pug 2.0 HDI owner
