Latest: BootIt
Overall: 17110
Online Now [138]:
Visitors: 138
Today: 2238
Total: 93383394
Forums › The Car › 206 Talk › 'Indexing' Spark Plugs
PostPosted: Sun Jun 02, 2013 8:38 am Up
Any thoughts on this from wiki?
Indexing spark plugs:
A matter of some debate is the "indexing" of plugs upon installation, usually only for high performance or racing applications; this involves installing them so that the open area of the spark gap, not shrouded by the ground electrode, faces the center of the combustion chamber, towards the intake valve, rather than the wall. Some engine tuners believe that this will maximize the exposure of the fuel-air mixture to the spark, also ensuring that every combustion chamber is even in layout and therefore resulting in better ignition; however, others believe this is useful only to keep the ground electrode out of the way of the piston in ultra-high-compression engines if clearance is insufficient. In any event, this is accomplished by marking the location of the gap on the outside of the plug, installing it, and noting the direction in which the mark faces; then the plug is removed and additional washers are added to change the orientation of the tightened plug. This must be done individually for each plug, as the orientation of the gap with respect to the threads of the shell is random. Some plugs are made with a non-random orientation of the gap and are usually marked as such by a suffix to the model number; typically these are specified by manufacturers of very small engines where the spark plug tip and electrodes form a significantly large part of the shape of the combustion chamber. The Honda Insight has indexed spark plugs from factory, with four different part numbers available corresponding to the different degrees of indexing to achieve most efficient combustion and maximum fuel efficiency
PostPosted: Sun Jun 02, 2013 10:30 am Up
But how would you know which was was the best? Benefits or gains would be unnoticeable I'd say.
