Latest: flipflap
Overall: 17140
Online Now [276]:
Visitors: 275
Today: 38185
Total: 113945269
Forums › Tuning, Modification & Legal › Project Cars › 206 GTI Kompressor sleeper
deadrange2001
PostPosted: Mon Aug 13, 2012 2:30 pm Up
OK, I'm going to be short here.
Pics gradually go here: www.flickr.com/photos/84722500@N03/
Flywheel power is 210 HP, torque 240 Nm available from 1500 to 7000 rpm Smile
Boost is 0.8 bar.
Here's the list of all mods done until now:
- Starring Eaton M62 clutched supercharger from a Merc SLK230 Smile
- OZ Racing 17" rims
- Water piping reconstruction + rerouting (inox)
- Custom 18.5cm crank pulley + custom belt
- Custom intake manifold
- Clutch reinforcement (adjusted flywheel)
- Oil cooler (water)
- Custom steering pump (electric) + hoses
- Engine head adjustment
- Forge bypass valve
- Motul gearbox oil
- Oil change + filter
- ARP gasket bolts
- BORLA complete inox exhaust 63mm
- Lancer Evo X catalyst
- New engine heat exchanger
- NGK spark plugs
- Adjusted clutch cable
- Pirelli Pzero Nero 205/40/17 tyres
- Exhaust thermoband (exhaust manifold + downpipe)
- Bosch bigger fuelpump (2.0 TFSI)
- 470cc injectors
- K&N sportfilter + Samco hoses
- Enlarged cold air intake
- 206RC exhaust manifold
- modified gearbox linkages + shortshift
- Unichip piggyback
- DP_Engineering decompression plate
- OMP front strutbar
- Quaife LSD
- 206RC rear suspension/axle + powerflex mounts + KYB Ultra-SR sport dampers
- Front Eibach Pro springs
- Water/methanol cooling (Devil's Own) Stage 1
- Alpine 9812 HU + MacAudio MPX4000 + Pioneer TS-A171CI + Pioneer TS-G1312
- New brake discs and pads (ATE)
- Lowered as much as possible
- Metabond oil treatment
To be done:
- powerflex bushes for front
- vibratechnics engine mounts (f***ing engine keeps breaking its mounts !@$#$^%@)
- intercooling (IAT is killer!)
- modify front grilles (for more air!)
- hood scoop for more air!
- switch to 283mm brakes in front (need braking power!)
- new front dampers (KYB Ultra-SR or Bilstein B4/B6 for better mass transfer)
PostPosted: Mon Aug 13, 2012 2:34 pm Up
Sounds good but the only bit im intrested in is the water/methanol cooling.....
deadrange2001
PostPosted: Mon Aug 13, 2012 2:40 pm Up
w/m cooling will be used as temporary remedy for IAT reduction Sad
Tuner engineer has insisted on non-intercooled design, now engine heat is dangerous for summer day driving so he suddenly changed his mind Sad
W/m will be used later on only for temporary meth boost, intercooler will lower temperatures properly.
PostPosted: Mon Aug 13, 2012 2:43 pm Up
seriously doubt how much cooling effect will the meth/water spray give you.
myself and steve both got the kit set up and we got very minimal gain on power before intercooling. We only got 2L engine so can't really run oversize nozzle
PostPosted: Mon Aug 13, 2012 2:44 pm Up
No cooler?!
Well that is strange....
How much roughly did the meth setup cost? As im currently just investing in a cooler spray rather than injection
PostPosted: Mon Aug 13, 2012 2:49 pm Up
Addaz wrote:
No cooler?!
www.efi-parts.co.uk/in...ductID=205
www.methanol-injection...77caaaedae
deadrange2001
PostPosted: Mon Aug 13, 2012 2:55 pm Up
Yes *it is strange*; it is also inefficient and dangerous for the engine. This is what I said too to the tuner engineer but he seemed to convince me somehow to go on. However, I am not (yet) car engineer, but I am quick learner. Space is a huge problem in the engine bay for any kind of intercooler piping if supercharger is placed as in my photo. Will attempt a swap with the alternator (new mounts, sh.it) or will totally quit air conditioning Sad Not too good for a black car in summer time.
Meth setup was about 300 EUR + installation.
PostPosted: Mon Aug 13, 2012 2:58 pm Up
if you really running out of space you could run charge cooler. The cooling core are located in-line with your supercharge pipe work.
www.chargecooler.co.uk...8581d7546a
deadrange2001
PostPosted: Mon Aug 13, 2012 3:13 pm Up
Thanks for the tip but the operation space for that is really small (check engine picture, lefthand side). I kinda need to put a 90 degree angle hose out of the supercharger and this will definitely kill airflow Sad
It will be a project for this winter... Smile
D4NTP
PostPosted: Mon Aug 13, 2012 4:07 pm Up
Mines s/c but no intercooler. runs fine.
PostPosted: Mon Aug 13, 2012 10:28 pm Up
very nice work mate,it's interesting how much the engine bay can hold..heheh
deadrange2001
PostPosted: Tue Aug 14, 2012 12:48 am Up
For the moment engine mounts keep breaking Sad
D4NTP: can you please give me a link to your s/c project?
PostPosted: Tue Aug 14, 2012 1:59 am Up
ignore him, he got a toyota and it's S/C from factory Laughing Laughing Laughing
deadrange2001
PostPosted: Tue Aug 14, 2012 7:09 am Up
I see, thanks Smile
D4NTP
PostPosted: Tue Aug 14, 2012 12:23 pm Up
ignore you! lol
