Latest: jeromequi
Overall: 17111
Online Now [197]:
Visitors: 197
Today: 737
Total: 93639562
Forums › The Car › Solved 206 Problems › Overheating, no cooling fan.
Go to page Previous  1, 2
JamJar93
PostPosted: Sat Oct 19, 2013 9:58 am Up
Yo, currently having a similar problem its a 1.1 zest2... checked most of the wiring and fuses.. all fine.
checked the power going to the fan and there isn't a reading.. Just wondering if any of you lovely people have any info on this... its driving me maad!
PostPosted: Sat Oct 19, 2013 10:24 am Up
When did you check the power? In a condition when the fan should be on?
JamJar93
PostPosted: Sat Oct 19, 2013 10:33 am Up
Yeah whilst the engine was running I built the temperature upto a good 95 degrees which is when the fan usually came on then checked the power.. right at the fan where the terminal plugs into the actual fan and there was no power :((
conker1221
PostPosted: Tue Apr 07, 2015 1:20 pm Up
Could anybody point me to the correct relays, and fan resistor for my peugeot 206 1.4 8v? Thanks, information on ebay is never straightforward!
tRiCk
PostPosted: Tue Apr 07, 2015 4:58 pm Up
Have a look at the relays under the cover on the left of the cooling fan facing outwards u should find corrosion
Page 2 of 2
