Posted: Thu Oct 24, 2013 8:34 am |
Posted: Thu Oct 24, 2013 4:16 pm |
Very nice! I remember there being a soft-top on there before - have you removed it, or just bolted another roof on?
Posted: Thu Oct 24, 2013 4:57 pm |
20Drift wrote: |
Very nice! I remember there being a soft-top on there before - have you removed it, or just bolted another roof on? |
Yeah the soft-top folds away into the boot as if you would if you wanted the roof down then you just drop on the hard roof by removing two plastic covers where these 2 pins drop into for the electrics i.e. rear heated screen and interior roof lights. 2 min job
Posted: Fri Oct 25, 2013 2:38 am |
lukesaunders91 wrote: |
20Drift wrote: |
Yeah the soft-top folds away into the boot as if you would if you wanted the roof down then you just drop on the hard roof by removing two plastic covers where these 2 pins drop into for the electrics i.e. rear heated screen and interior roof lights. 2 min job |
VERY NICE
Bet you couldnt do it on your own though, 2 man job?
Posted: Fri Oct 25, 2013 3:47 am |
Trade Rating: +13
That is the most awesome thing I have seen on a car! It's a BMW transformer! Hard top, soft top and no top! I am not a BMW fan as I have said before, but you car is looking like an exception to that rule!
Posted: Fri Oct 25, 2013 3:59 am |
Looks nice Luke,
I'd remove the rear 320 cd badges myself.
Posted: Fri Oct 25, 2013 10:42 am |
thats a sweet looking ride
Posted: Fri Oct 25, 2013 11:04 am |
I'd leave the badges where they are.
