Latest: DanDan17
Overall: 17128
Online Now [89]:
Visitors: 88
Today: 25082
Total: 100499866
Forums › The Car › 206 Problems › GTi 180 feeling under powered :(
stustu1981
PostPosted: Fri Dec 27, 2013 2:26 pm Up
Hi everyone,
Hope you all had a great christmas. I've got a 2004 GTi 180 which has a custom full stainless exhaust system, k&n panel filter and been mapped by Rstuning. I had the gearbox replaced a couple months back and since I've had the car back it seems to feel very under powered?.?.? The rolling road printout states 170bhp after the map was added but it drives more like a 1.4
Even keeping up with traffic, it seems I have to give her a proper boot.... Does anyone have any idea what could be happening? or if anyone is local in the Nottingham/Hucknall areas could anyone pop by to advise me on it?
Many many thanks[b]
Kale
PostPosted: Fri Dec 27, 2013 2:58 pm Up
Intake clogged? Catalytic converter collapsed?
These are the first things that popped in my mind. Does the exhaust sound "free"? Would not be the first remapped car to melt its cat.
306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro
stustu1981
PostPosted: Fri Dec 27, 2013 3:07 pm Up
Both good suggestions and definitely a starting point, hate the way it drives right now as it should have so much more grunt
Kale
PostPosted: Fri Dec 27, 2013 3:48 pm Up
Does the car start up easily? My 306 S16 was a bad starter when the catalyst was going. Finally it didn't start at all because the cat was all clogged up. Also its performance degraded gradually.
Go under the car and knock the catalyst, if it sounds there is something loose then you are the winner Very Happy
Though - my 306 has destroyed 2 cats. The 306 cat has two chambers, the engine side was collapsed to dust and clogged the rear one. Second time it had just melted because the camshaft timing wasn't accurate. There were a couple of pieces left inside and one was jammed to the centre pipe side of the cat and clogged exhaust.
On the first time the damage was probably because the catalyst was from a car which was flipped over and it had got a hit from something. The first chamber material was cracked and then collapsed to dust over time. On the 1st time it didn't sound anything special when I gave it a hit. Second time it was obvious.
stustu1981
PostPosted: Fri Dec 27, 2013 4:16 pm Up
Starts and runs perfect with no odd changes in power or drive it's just so under powered lately which is confusing me...
mattymj
PostPosted: Sat Dec 28, 2013 1:41 am Up
Rear brakes binding?
broadblaster
PostPosted: Sat Dec 28, 2013 2:54 am Up
vvt valve stuck/gummed up ???? but if you say its been like this since gearbox has been changed have you been back to whoever done it and said anything to them.
on a back road playing
Nick_C
PostPosted: Mon Dec 30, 2013 1:13 pm Up
Was a 180 box definitely put back in?
Nick
Peugeot 206 GTI 180
Currently breaking a 2001 206 GTI - please contact for details/parts
PostPosted: Mon Dec 30, 2013 4:04 pm Up
Throttle position sensor?
