Posted: Wed Apr 09, 2014 12:44 pm |
Posted: Wed Apr 09, 2014 1:39 pm |
Back box might be a waste ... diesel exhausts work differently to petrol ... it will look better though granted!
Get crystal lights for fronts too ... the single H4 bulbs are cr@p ...
Posted: Thu Apr 10, 2014 10:57 am |
Nice to see another 1.4HDi, looks pretty tidy and a real early one at that. Couple of good plans there. definitely replace the standard rear exhaust box. you'll get a nice DI Growl then .
I keep meaning to remap mine but always find something extra to do so just doing it all before I get it mapped.
Posted: Thu Apr 10, 2014 12:19 pm |
cheers guys....
washers came today
still waiting on the rear lights.
and yes i forgot about the headlights
Posted: Thu Apr 10, 2014 12:46 pm |
Get rid of the standard air box, get a cone on it with a direct cold air feed, make sure its a big cone though!
Also fit a decent front mount then get her mapped, and I expect you will be presently suprised!
| Team Impossible Possible
Posted: Thu Apr 10, 2014 2:47 pm |
dont have the cash for a FMIC yet.... but i would like too
i thought just a k&N panel filter will be fine on a diesel?
also are crystal lights a straight swap?
thanks
Posted: Fri Apr 11, 2014 12:30 am |
sorry double post...
would a intercooler from a 1.4Hdi C3 be ok?
thanks
Posted: Fri Apr 11, 2014 12:45 pm |
kirk46 wrote: |
thanks |
Think the power steering pipes that run across get in the way, i looked into taking the 1.6hdi cooler and putting it on mine but it was too much hassle in the end, ended up buying a small used fmic but again, couldnt really be bothered, so im buying a gti instead lol
Posted: Sat Apr 12, 2014 9:03 am |
hmmmmm thought it would be an easy fit
just been looking at a friends 207 1.6Hdi and it isnt much different at all...
Posted: Sat Apr 12, 2014 4:37 pm |
The 206 1.6 hdi is the same engine as the 207 (i think) its also a modified version of the 1.4 you have, just with slightly bigger cylinders and a couple of other bits including the intercooler
Posted: Wed Apr 16, 2014 10:44 am |
few updates:
got these:
and there fitted along with a straight through back box
mist washers
replaced the droplinks.
need to order wishbones as mine are fubard :/
also found a leak from a seal heres the pic
that rubber seal if thats what it is was a few mm away from the transfer box or whatever its called and it leaking gear oil
Posted: Thu Apr 24, 2014 4:17 pm |
Posted: Sun Apr 27, 2014 5:32 am |
Trade Rating: +13
A remap was the first mod I did on my 1.4hdi, by far the best £200 I've spent on any car!
