Posted: Sun Mar 23, 2014 3:47 pm |
my wishbone rubbers have finally gave way the car had been standing for 10 months before I bought it and after 6 months there's a noticeable clunking sound on full lock and steering seems to have more understeer. This along with the fact the rubbers look like s**t. Also I haven;t serrviced it since having it so I thought i'd have a go.
soooooo, I've bought
2 new wishbones
2 anti-roll bar linkages
2 Track rod ends
Some 266mm vented grooved & drilled discs for £13 not sure they'll fit my 1.1 206 but if not I can buy some more and fit the grooved one to my 306 hdi when I get round to buying one
5 litres of 5w40 fully synth oil
New sump plug washer
Mann oil filter
Eicher front brake pads
2 litres of coolant as mine is a bit overdue
I mean it may not be necessary for new track rods but for £16 why not and if you've ever removed these off an old car before you'll know where im coming from (they just F***in spin)
and thats all for now should this cover the main things?
Posted: Sun Mar 23, 2014 5:46 pm |
if you bought the cheap euro wishbones be prepared to take them off again very soon as they dont hold up to much. and vented discs for £13? id worry about standard solid disc for that price tbh. good luck to ya
| Joined the GTi massive 10/1/13
Goodbye lairy Pugani (quicksilver 1.4)  | |
Posted: Mon Mar 24, 2014 4:00 am |
Discs won't fit a 1.1 They'll be about 19mm too big
| Mr-Tigger wrote: |
| and vented discs for £13? id worry about standard solid disc for that price tbh |
I picked up a set of Pagid discs a couple of weeks ago from ECP for £17 a side, list price was £90.
Although they do some good deals, some of the makes they are selling I wouldn't put on my worst enemies car. ECPs cheap brake range (Eicher) are not worth the money, you'd be better off shaping brake pads from a block of cheese and taking your chances with them rather than cheap Indian imports.
| doski wrote: |
2 new wishbones
2 Track rod ends
Mann oil filter
and thats all for now should this cover the main things? |
Spark plugs?
Air filter?
Pollen filter?
Depending on age, new brake fluid?
If you're changing the coolant, is the timing belt due soon? No point draining the coolant twice.
