Latest: williamekstrom
Overall: 17124
Online Now [103]:
Visitors: 102
Today: 16835
Total: 99348836
Forums › The Car › 206 Problems › 1.6 16v oil level sensor
rsbpug205
PostPosted: Fri Apr 04, 2014 4:41 am Up
Cheers all,
Can you help me where to find the oil level sensor location on the 1600 16v engine?? I need to verify if it needs replacement since the oil level display on the instrument panel shows dashes only (------) and not the usual blocks although the dipstick indicates oil level full?? Please post photos if possible
Many thanks
DREWDEN
PostPosted: Fri Apr 04, 2014 5:50 am Up
The oil level indicator can be very eratic, i would sugest testing first, by parking the car on flat ground with the engine off, (of course) for ten minutes handbook sugestion, then seeing if it then reads correctly.
The only time you have real problems would be if the dashes are flashing.
206 2ltr Hdi glx 53 plate
PostPosted: Fri Apr 04, 2014 6:14 am Up
It could be the known bug in the BSI software. Try a reboot first, failing that, it would be a trip to the dealers for a software update.
The sensor is located just to the left of the oil filter (visible from top)
