Latest: Worthy967
Overall: 17143
Online Now [524]:
Visitors: 523
Today: 116114
Total: 115147175
Forums › The Car › 206 Problems › car cutting out
car cutting out
jamie-38-206
PostPosted: Sat Mar 29, 2014 6:06 am Up
Hi,
my car has cut out a few times when no accelerating (i.e coasting downhill or turning round corner) It does not happen all the time. 2 times in last 7 days. the car start back up right away and is fine.
I recently installed new coil pack as I thought this was problem. Car running a lot better with new coil pack and plugs but still left with this wee problem now and again.
The mechanics reader said it was the coil pack as the engine management light came on a while back.
any ideas? would like to try and have a go at it myself before paying mechanic.
Any help would be most appreciated.
dladdin
PostPosted: Sat Mar 29, 2014 6:08 am Up
mine did that other day about 8 times but now it fine.... the second you put the clutch done engine would cut out.....
Hawkers
PostPosted: Sat Mar 29, 2014 7:33 am Up
www.206info.co.uk/Foru...ottle.html
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
jamie-38-206
PostPosted: Sat Mar 29, 2014 9:53 am Up
thanks. will try the above link and let you know how i get on.
Many thanks
jamie-38-206
PostPosted: Tue Apr 08, 2014 11:49 am Up
Hi,
now been a week now since I followed the guide above to clean the throttle body and MAf sensor. I also changed the air filter at same time.
So far so good (fingers crossed) car not cut out since and running better. Smile
many thanks for your help everyone.
206 1.4 - 2004 (TU3JP)
jamie-38-206
PostPosted: Wed Apr 09, 2014 10:53 am Up
Spoke too soon with my reply last night. The car briefly cut out as before today when coming down a steep hill. It cut out as soon as i put my foot on clutch but started right away again.
PostPosted: Mon Apr 14, 2014 5:46 pm Up
Remove and clean ICV again. It sometimes takes a few times to get att the crud out.
