Online Now [1149]:
Visitors: 1148
Today: 241852
Total: 151721221
Forums › The Car › 206 Problems › Unsolved Overheating Problem-Couples of Symptoms Together!
Go to page Previous  1, 2, 3, 4
hamed206
PostPosted: Sat Oct 11, 2014 8:29 am Up
gazza82 wrote:
Expansion tank is plastic and can crack if over tightened You will hear if you get engine hot and listen..
Depends what you used to flush rad and hiw badly plugged up it is. Did you take rad out and flush through with hose etc the wrong way?
I think he meant normal oil in engine. Very low oil can cause overheating too.
I flushed the radiater using the 10 minutes Gunk flush product by pouring the entire bottle in the tank and run engine for 10 min then drain the system. I followed the instructions written on the bottle.
My oil level is good. I replaced it with the filter when problem started to occur.
Hamed
copey
PostPosted: Sat Oct 11, 2014 1:18 pm Up
you tried the dye stuff?
02 2.0 hdi d turbo
hamed206
PostPosted: Mon Oct 13, 2014 7:21 am Up
What is this please?
Hamed
hamed206
PostPosted: Wed Oct 29, 2014 6:56 am Up
Still no hope to fix! And the engine management light started to flash more frequently, car hesitates when the engine management light come on. Could this be related to the overheating probably????
Hamed
Oafie
PostPosted: Wed Oct 29, 2014 12:03 pm Up
hi mate
Oafie
PostPosted: Wed Oct 29, 2014 12:17 pm Up
hi mate, might sound silly but have you checked the carpet under your glovebox area? if it's damp your heater matrix is leaking, as for the misfiring and eml flashing, when was the last time you checked the spark plugs? I had the same problem on mine a couple of months ago, turns out 1 of the spark plugs was breaking down, changed them and not had a problem since.
hope this works for you
lip_88
PostPosted: Wed Oct 29, 2014 2:19 pm Up
Definitely check the bottle had one go on me before but if not Get a sniff test done on it could well be the head gasket
hamed206
PostPosted: Sat Nov 01, 2014 7:58 pm Up
I don't use the heater matrix at all. I canceled long time ago! Weather here is mostly hot in the whole year!
As for the spark plugs, you are right, they worth checking.
I'm still unable to solve the overheat problem and so much disappointed so Sad
Hamed
hamed206
PostPosted: Mon Nov 24, 2014 1:25 pm Up
Both problems sound related!
206info.co.uk/Forums/v...art=0.html
Now it is cutting out several times when idling and when driving. Engine management like come on while driving and I lose all power in the accelerator pedal for seconds, then it return to normal but the fan kicks!!! Many things are playing up together. Fan kicks, engine management light come on and off, fan kicks when light is on, car hesitates, poor overall performance and acceleration, also the car overheats on the high way. No one really is able to help or to advise about something.
Sounds ECU Mad
Hamed
Oafie
PostPosted: Mon Nov 24, 2014 3:46 pm Up
try a compression test, that will tell you if your head gasket is causing your problem.
Page 4 of 4
