Posted: Tue Nov 25, 2014 10:22 am |
About 2 weeks ago had a problem with a 53 1.4 Quicksilver where MFD showed Anti-Pollution fault & engine was misfiring but then cleared itself & been fine since. Plugged in PP2000 today just to see what faults was recorded. Came up with "Intermittent fault ignition misfiring' & 'intermittent fault Adoption of the quantity of air entering the manifold'.
PP2000 then showed the fault can be caused by
-Damaged connection of harness
-Faulty Control Unit Calibration.
So does this mean Coil Pack faulty? or something else
| DW & his 2004 Red 206 GTi 180 | |
Posted: Tue Nov 25, 2014 5:15 pm |
Personally, I would shove a set of plugs and coil pack on it and see how you go
Coil and plugs normally fix most things
| Team Impossible Possible
Posted: Tue Nov 25, 2014 7:12 pm |
Posted: Thu Dec 04, 2014 1:16 am |
I have exactly the same symptoms as this changed both spark plugs and coil pack made no difference any other ideas cheers
| black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust | |
