Latest: Worthy967
Overall: 17143
Online Now [618]:
Visitors: 617
Today: 90316
Total: 115734597
Forums › The Car › 206 Talk › Wheels & Tyres
Wheels & Tyres
Spotfist
PostPosted: Fri Jan 16, 2015 7:17 am Up
My head just can't take it any more, I have trawled the entire internet looking for the correct tyre size for the 15" alloys on my 1999 206 GTI (137).
Using the faq here I found these,
- 14" wheel - 185/60/14 or 175/65/14
- 15" wheel - 195/50/15
- 16" wheel - 195/45/16 or 205/45/16
- 17" wheel - 205/40/17
- 18" wheel - 215/35/18
- 19" wheel - 215/35/19
So my tyres would be the second in the list, however these figures conflict with EVERY other website I have found and none match
185/55 R15V from here - 206gti.net/faq/#9
195/50 R16 from here - www.wheel-size.com/
Please for the love of all things good can someone put me out of my misery and let me know what size tyre was fitted as standard or the recommended OD for the car. At the moment I have 195/45/15's on.
PostPosted: Fri Jan 16, 2015 7:24 am Up
Whats the VIN number?
Ill have a look on Peugeot Service Box for you to see what tyre size it rolled out the factory with.
FWIW im running 185 55 15 V Goodyear Efficient Grip Performance tyres on the 15" GTI rims.
Spotfist
PostPosted: Fri Jan 16, 2015 7:53 am Up
Cheers the vin# is vf32crfre40311060.
I would have thought that the outer diameter of all the wheels would be very close otherwise each car would have to have a different calibrated speedo and odometer?
Your 185/55/15 's have an OD of 585mm while the 195/50/15's have an od of 576 so are pretty close as opposed to the 195/45's I have on at the moment.
PostPosted: Fri Jan 16, 2015 8:00 am Up
185/55 15 tyres is what it rolled out the factory with.
Spotfist
PostPosted: Fri Jan 16, 2015 8:02 am Up
Cheers for that!
uttz
PostPosted: Fri Jan 16, 2015 8:59 am Up
IMO 185s are a skinny i dont think i'll go less than 195s
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
PostPosted: Fri Jan 16, 2015 9:09 am Up
There is an option in the BSI to change wheel/tyre size and this adjust the speedo accordingly.
Spotfist
PostPosted: Fri Jan 16, 2015 9:21 am Up
Aaah that makes sense although it's 1999 so no BSI?
Anyways, the main reason was to check the % difference between my current tyres and the originally fitted ones. if I do change I will probably go with uttz 195/50/15's.
Car goes in for axle and exhaust replacement next week so wont be any time soon though lol
PostPosted: Fri Jan 16, 2015 9:48 am Up
You still have a BSI, just not as complicated as it doesn't have the VAN system
Spotfist
PostPosted: Fri Jan 16, 2015 10:25 am Up
Cheers for that bit of Info, much appreciated.
