Latest: DanDan17
Overall: 17128
Online Now [55]:
Visitors: 54
Today: 20951
Total: 100495739
Forums › The Car › 206 Problems › What activates the radiator fan?
razza987
PostPosted: Tue Mar 17, 2015 4:11 pm Up
I've removed the standard rad, fan and cowling from the race car. I'm replacing the rad with a Golf GTi one and an aftermarket fan. The standard rad doesn't have a thermo switch fitted, so what sensor/switch activates the fan?
Cheers,
Raz
206 GTi Circuit Racer
Tricolore Trophy
www.trackattackraceclub.com
PostPosted: Tue Mar 17, 2015 4:18 pm Up
the 206 don't have any switch fitted on the radiator itself,only the temp. sensor,and the fan relay and ECU controls the fan to kick in.
PostPosted: Wed Mar 18, 2015 1:19 pm Up
The ecu uses the coolant sensor to tell how hot it is. If it wants to switch the fan on it triggers one of two relays to switch the fan on.
razza987
PostPosted: Wed Mar 18, 2015 3:26 pm Up
Ok cheers guys.
As I have an Emerald ECU, I guess the fan temp must be controlled by that
Tricolore Trophy
PostPosted: Wed Mar 18, 2015 4:21 pm Up
If the original ECU is still in place and has its own coolant sensor it can stay where it is and control the fan.
I've got mine controlled by the Omex ECU and I can control the on and off temperatures.
razza987
PostPosted: Wed Mar 18, 2015 5:08 pm Up
I'll have to find the lead and plug in for a look, it's been 2 years since I last looked at what the ECU settings are
Tricolore Trophy
