Latest: DanDan17
Overall: 17128
Online Now [60]:
Visitors: 58
Members: 1
Today: 24380
Total: 100499165
Forums › The Car › 206 Problems › Peugeot 206 1.4 16v does not pass the 1800 rpm
CarlosMSV
PostPosted: Mon Mar 16, 2015 12:06 pm Up
Hello I have a serious problem in the car, the overnight my 206 "broke". So am I start the car and suddenly the acceleration was in the 950rpm or so (and mine is 500rpm), as was cold I thought that was it, I go out with the car and realized that he was failing immense that's when I've decided not to go out, accelerating simply does not pass the 1800rpm and then fails, gives 2 spin fluctuations but never moving from 1800rpm and then turns off. At first got me away with disconnecting and reconnecting the battery or using the PC with that OBD device 20 €, able to walk with the car for 1 month, but now is really difficult today I had about 30 minutes always trying for it to work and nothing. I turned off the battery and went away, 1 h after this, reconnected the battery and turned on without any problem, so do not even understand what it may be. The error is detected in the program is this:
P1621 - ECU failure
- Internal fault
- A week ago I went to a workshop, the mechanic called the machine and said there that the brake pedal sensor was not working, he explained to me that it was a 4-pin plug, 2 for the lights and 2 for ECU. So I sent for a new sensor, turned out to clear the error. I drove for a week, but today there again, honestly think I will put the car in Peugeot, no longer know what to do. I've been told it was the ECU was no life and I have to by a new unlocked.
Thanks in advance.
Hawkers
PostPosted: Mon Mar 16, 2015 1:43 pm Up
You say you disconnected the battery. Did you follow correct procedures for doing this as stated in this topic. www.206info.co.uk/Foru...nners.html
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
CarlosMSV
PostPosted: Mon Mar 16, 2015 2:25 pm Up
No, unfortunately I did not know you had to do this
CarlosMSV
PostPosted: Tue Mar 17, 2015 12:50 pm Up
Anyone ?
PostPosted: Tue Mar 17, 2015 1:04 pm Up
Tbh mate, take it to peugeot. They will advise you the best
CarlosMSV
PostPosted: Wed Mar 18, 2015 9:43 am Up
Hello, I sent the ECU for a good electrician and he said it is the ECU problem. I'll have to find one Shocked
commandosqueak
PostPosted: Wed Mar 18, 2015 2:29 pm Up
in that case just go to pug, at least they know what they are doing
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Wed Mar 18, 2015 3:29 pm Up
not forgetting the BSI and the immo chip Wink
