Latest: Andyblue64
Overall: 17123
Online Now [262]:
Visitors: 261
Today: 45114
Total: 97945436
Forums › The Car › 206 Problems › GTI 180 stiff steering?
Neepamonsteri
PostPosted: Wed Apr 01, 2015 10:24 am Up
Hi guys!
Steering feels pretty stiff on slow/very slow speeds.
is it just my car or 180 in general?
all good on higher speeds but slow speeds it feels a bit too stiff. Makes me wonder if power steering is adjusting with the speed or not. Shouldnt GTI 180 have adjusting one? (not sure what it's called)
any ideas?
Vexs
PostPosted: Wed Apr 01, 2015 11:06 am Up
The 180's steering is more responsive at higher rpms and feels heavy at lower rpms, its designed this way.
My GTI 180
My Old 1.4 8v
Neepamonsteri
PostPosted: Wed Apr 01, 2015 4:20 pm Up
Ohh, so its meant to be that stiff on low rpms?
I mean one doesn't smoothly roll around on a parking lot one-handed on low rpms.
That stiff, is this normal?
Btw, what do you think if I go from 205 wide tires to 215, will it feel even stiffer with only 10mm added wideness?
Project2062014
PostPosted: Wed Apr 01, 2015 8:24 pm Up
Check the tyre pressures run 38/34 psi
Fnt/bk
. If you try to turn fast the steering goes stiff. depending on you speed ..
