Latest: DanDan17
Overall: 17128
Online Now [251]:
Visitors: 250
Today: 25075
Total: 100625481
Forums › The Car › 206 Talk › a slight setback
a slight setback
lip_88
PostPosted: Fri May 08, 2015 3:53 pm Up
So my gti flew through its mot today after a pretty good overhaul it bloody should have! First real good run around in it today and the accelerator cable clip the one used to adjust the cable has done a disappearing act does anyone know where I can get one other than peugeot who I'll be on to first thing anyway?
PostPosted: Sat May 09, 2015 1:04 pm Up
Pm Edward. They always fall off. I'm sure he used a paperclip as a replacement.
PostPosted: Sat May 09, 2015 1:13 pm Up
I did yes! It was something like a paperclip anyway.
lip_88
PostPosted: Sat May 09, 2015 2:13 pm Up
I've made my own now in a similar fashion but it's alot more secure than before cheers chaps
