Latest: evert
Overall: 17112
Online Now [37]:
Visitors: 36
Today: 9125
Total: 93706289
Forums › The Car › 206 Problems › Axle Stands
Axle Stands
jamie-38-206
PostPosted: Sat May 16, 2015 8:52 am Up
Hi, this may seem like a stupid question but is it ok to put axle stands under the sills near the conventional jacking points?
Cheers
206 1.4 - 2004 (TU3JP)
Pp4811
PostPosted: Sat May 16, 2015 9:30 am Up
I would say no, try to put them under the bottom arm or subframe. That will be a stronger place to balance the weight of the car on.
206 gt - gone (sadly)
206 gti 2003 - Sahara yellow - gone
206 gti 2002 - silver - present car!!
PostPosted: Sat May 16, 2015 10:39 am Up
No. I have seen many bent sills this way. It is OK if you put them on the lip of the sill but even then you want some soft packing to avoid cutting through the undercoat and paint and creating a point for corrosion to start.
